- 501F
- Sub Zero
- More than 10 years
We have a pair of subzero 501 built in refrigerator and freezers. Even though they are from 1987, the appliance repair professional we initially had come look at another appliance had from the beginning said that he would never replace them. Any part that needed work he could get.
We initially had him come back to look at the refrigerator side. The refrigerator was having by freezing and condensation problems and the hose to the drip pan was clogged. This was fixed by adding a second thermometer to balance the interior temperatures and replacing one of the heater units underneath to keep the hose to the drip pan from freezing.
At the same time we asked why our freezer was forming ice in the bottom (but otherwise working as it should). The answer was that both defrost heaters had stopped working. Those were replaced and the unit started working as it should.
Until it didn’t. Repeatedly.
A few weeks later we noticed the freezer temperature increasing rapidly. He was back out that night and replaced the compressor switch assuming it had been ready to break, and just happened to happen then. A month later we returned home from vacation to a room temperature freezer with rotting food. The diagnosis was the compressor had failed and it was replaced. Since we were offered a deal, we decided to go ahead with the ice maker install that we had wanted for some time. While he was back two weeks later to install he noticed it still wasn’t getting down below 7 or 8 degrees. He balanced the refrigerant levels and replaced the switches on the door having determined that they weren’t functioning and the fan was not turning on.
Now a month after this the we noticed our food was starting to thaw. We checked the temperature and it was only maintaining refrigerator temperatures. It stayed at 40 all evening. This morning it was 50 and climbing fast. When it was starting to heat the interior and was reaching 80 I turned it off. So what gives? We’ve touched basically every major component of this unit and it’s still having problems. We are call8ng in another repair this morning but I wanted to see if anyone else had any thoughts.
