Results 1 to 3 of 3
Thread: e57 error code
    Aug 2015
    florida
    Default e57 error code
    Model Number: EIFLS55IRR0
    Brand: Electrolux
    hello,
    i tried searching for this code but couldnt come up with anything. i have a elctrolux EIFLS55IRR0 front load washer and am getting error code 57 i checked the tub and motor and they spin fine and did a ohm check and cam up with 3.7 ohms from pin 1-2 1-3 and 2-3 it says in the troubleshooting manual it needs to be 4-6 ohms just making sure that that .3 ohms is a big deal. also to be sure looking in the machine from the back panel pin 1 is all the way to the left on the motor. thank you for the help.
    Oct 2004
    I have not seen that code before but I found a couple of posting that said if the lock and motor are ok, this board was replaced and corrected the issue...
Size:  2.9 KB Motor Control Board
    ...point3 ohms shouldn't make a difference.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Yeah I've got O.C.D.....Old, Cranky and Dangerous.
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Jul 2006
    E57 is high current on inverter. Same troubleshooting steps as E56 so you did good. Three tenths of one ohm doesn't sound like much but you're already below the lower end. Ohm's Law, less resistance equals more current. E56 and E57 are both high current error codes. Your call, too close for me to call. Order both and return the one you don't need for a full refund less shipping.
    Drive Motor 134638900 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Motor Control Board 134618201 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. Whirlpool Duet Dryer Start Error - Error Code 08
    By TJP in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 13th, 2015, 11:00 AM
  2. FIXED: Error code F20
    By loos34 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 12th, 2013, 09:41 AM
  3. Replies: 3
    Last Post: September 5th, 2012, 02:44 PM
  4. Fault Code F2 Error Code E6
    By bsmith in forum Whirlpool/Roper/Estate
    Last Post: February 20th, 2011, 02:11 PM
  5. whirlpool oven error code fixed problem still have error code
    By whodey79 in forum Whirlpool/Roper/Estate
    Last Post: November 1st, 2010, 12:25 AM
