Results 1 to 9 of 9
Thread: Electrolux error code E64
    Aug 2015
    Tennessee
    Default Electrolux error code E64
    Model Number: EWMED65HTS0
    Brand: Electrolux
    Age: More than 10 years
    1. The heating coil checks fine at the unit itself. 57ohms.
    2. Dryer is free from lint.
    3. There are two plugs for the heater. White plug with two grey and a white. And a green plug with Two white and one grey.
    4. Heaters turn on. 220v between each grey wire. No fault. Can run a whole cycle.
    5. 220v between grey wires on white plug a 139v between grey wire on green plug and the other two. Generates fault.
    It can run two days without faulting, other times it wont run two minutes. The 139v is the only anomoly so far.
    Model EWMED65HT50
    Last edited by rickgburton; August 29th, 2015 at 10:09 PM. Reason: Added Model Number
    Jul 2006
    Quote Originally Posted by PaulyC
    Generates fault.
    What fault? Stops heating? Stops running? Error code? What error code??
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Aug 2015
    Tennessee
    It heats fine, will dry a load of towels. Sometimes. I will usually have to reset the fault (E64) once or twice during the cycle.
    Jul 2006
    OK, remove the wires from the heating element and measure the resistance between the common terminal (the one by itself) and each of the other three terminals. Then measure the resistance between each one of the three terminals and the element housing. Make sure the wires are not connected to the element when you take your measurements.
    Rick is correct.
    I will add something that another member found with this same error code E64: FIXED Dryer Not Heating Error Code 64
    It was his breaker, so also check your breaker if the heating element ohm tests good. Breakers can wear out overtime and cause this intermittent issue.
    Jul 2006
    That's right! I remember reading that now that you mention it. Thanks J
    Anytime Rick.
    Mar 2016
    TX
    when you say BREAKER do you mean the one for the house? or is there one on the machine itself??
    Jul 2006
    The breaker for the outlet. It's probably a double 30 amp breaker.
  1. Demo code on electrolux
    By rgaggler in forum Frigidaire/Tappan/Electrolux
    Last Post: March 10th, 2015, 07:03 AM
  2. Electrolux washer EIFLW55HIW0 error code 21
    By riches in forum Frigidaire/Electrolux
    Last Post: August 15th, 2012, 02:03 AM
  3. electrolux error F10 code
    By farraad in forum Ranges/Ovens
    Last Post: February 14th, 2012, 12:18 PM
  4. whirlpool oven error code fixed problem still have error code
    By whodey79 in forum Whirlpool/Roper/Estate
    Last Post: November 1st, 2010, 01:25 AM
  5. FIXED: Electrolux error code 11
    By JJones in forum Frigidaire/Electrolux
    Last Post: August 1st, 2010, 10:24 PM
Tags for this Thread
