Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Samsung DW80F600UTS...No Power nor touchpad response until.....
    Dec 2015
    in my house
    Default Samsung DW80F600UTS...No Power nor touchpad response until.....
    Model Number: DW80F600UTS
    Brand: Samsung
    I unplug it for a handful of hours or so. The dishwasher is just under 2 yrs old...just died the other night showing no signs of life. I confirmed power going in..then unplugged it overnight. Next morning plugged it back in and worked like a charm...ran full cycle. got home that night...dead again. Unplugged for a handful of hours...and boom...back to life. Plugged it back in last night...this morning dead again. Can someone point me in the right direction? Need replace main control board?
    Oct 2004
    DW80F600UTS
    Look for a version # between the model# and serial#.
    4 things we have seen.
    House fuse/breaker.
    Loose main power wire/wire nut where the power enters the d/w.
    PCBoard.
    Key panal.
    If needed...
    Version 0
Size:  3.2 KB Power control board
    Version 01
Size:  3.6 KB Main Control Board
    http://www.applianceaid.com/
    Appliance Repair Aid
    Yeah I've got O.C.D.....Old, Cranky and Dangerous.
    I thought my dryer was shrinking my clothing.....turns out is was the refrigerator!
    Dec 2015
    in my house
    Thank you Jeff. It is either PC board or Key panel with very high probability of PC Board. there is consistent power to the unit and main power is NOT loose. Ten times out of ten that I tried...it requires several hours of being unplugged before replugging in will bring it back to life. AND it will work for at least an hour or two before it then dies again. The last few feet of the cord where it goes into the dishwasher is not disturbed at all during the plugging/unplugging. What this sez to me is that "something" in the circuitry is crapping out under the constant "pressure" of a power load...but not crapping out to a permanent death. Rather the unplugging for hours lets the residual/stored charge dissipate enough so that it can be brought back to life by plugging back in....until it does it all over again. When the unit IS working...the key panel responds per normal so I am "assuming" that is not the problem.
    But my REAL problem is this....There is NO version # on my tag...see attached. That being the case...and assuming it is indeed the PC Board....which one should I get in the absence of a version #?? Unit is roughly 2 years old.
    Also, if I do get a PC board and it proves not be the culprit...is it returnable?
    Again...much thanks.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Samsung Dishwasher Tag.jpg
    Oct 2004
    = version 0 ( zero )
    Yes...minus the shipping.
    Dec 2015
    in my house
    Thanks again. Order placed.
    Oct 2004
    Your welcome, if you get a chance...let us know how the repair went.
    Dec 2015
    in my house
    Well....not so good. I mean the boards swapped simple enuf. Got some power...started a cycle....it was in wash mode and then lights went out about 10 mins into it....but it seemed stuck in wash cycle which it was continuing to perform. Opened the door to interrupt and it went back to being completely dead. Plugging and unplugging did nothing.
    So I then unplugged it and took a peek in the power unit and all the wire nuts seemed snug. Put that back on...plugged it back in....went to the bathroom...and the thing starts up in wash cycle again...but again no lights. I've been letting it run about 30 minutes now and it just keeps going...no draining or nothing. Do you think it could be the key panel?
    Oct 2004
    Sounds like a different/new issue.
    Will it drain if you hold the start button down for 3-5 seconds?
    I'd be inclined to have the board replaced and do the key panal at the same time.....kinda suspicious of that one.
Size:  2.9 KB Touchpad
    Dec 2015
    in my house
    Nope...she is completely dead now. holding start button ....or any other button for that matter....for any length of time...gives no response whatsoever. So now I have dirty soapy water sitting in the bottom.
    Guess I'll have to order/try the key panel and see what happens...the old "diagnosis by wallet"!! If the key panel doesn't do it I'll return both parts and go buy a Bosch. If the key panel works with the new power control board...will try with the old power control board ....and if that works...return the power control board I didn't need.
    Thanks for the assistance. Very frustrating problem..and always extra fun around the holidays!!!
    Oct 2004
    Keep us posted.
  1. Replies: 13
    Last Post: February 23rd, 2016, 10:49 PM
  2. Replies: 5
    Last Post: November 19th, 2015, 10:03 PM
  3. Replies: 3
    Last Post: February 23rd, 2015, 09:00 AM
  4. Replies: 5
    Last Post: January 29th, 2015, 10:16 PM
  5. Replies: 6
    Last Post: January 21st, 2015, 08:49 AM
