Results 1 to 2 of 2
Thread: Samsung water in bottom of refrigerator - potentially easier fix
    Mar 2016
    Ohio
    Default Samsung water in bottom of refrigerator - potentially easier fix
    Model Number: RF266ABBPXAA
    Brand: Samsung
    I wanted to post this to the Samsung water in bottom of refrigerator thread but unfortunately it is closed.
    I have consistently had this issue for over a year and periodically remove the veggie try to dry out the water otherwise it overflows out of the fridge. However I noticed that I haven't had to remove the water puddle for a while so I looked under the veggie tray and to my surprise it is completely dry.
    The only thing I have changed recently is that propped up the front of the fridge with some small pieces of wood because it was leaning forward and wasn't quite level. Now it is level (maybe even slightly leaning back). So I am wondering if because it was leaning forward the water was prevented from going where it should and it somehow caused the issue.
    Anyways, I registered just to provide this feedback since this site was helpful to provide an even better fix in the closed thread mentioned above. Will post back here if the issue returns and this potential fix proves to be invalid.
    Jul 2006
    You may have already solved the problem by raising the front. When the machine goes into a defrost cycle the water needs to run out the drain hole under the evaporator. If it's not level or leaning too far in one direction the water can't drain.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. FIXED: Samsung water in fridge of bottom freezer unit
    By rufus in forum Samsung
    Last Post: March 23rd, 2016, 07:34 AM
  2. FIXED: RB217 Samsung water in bottom of refrigerator
    By jimnkristy in forum Samsung
    Last Post: March 15th, 2016, 01:49 PM
  3. Replies: 3
    Last Post: July 21st, 2015, 01:49 PM
  4. FIXED: Samsung Bottom Freezer Refrigerator Bleeping
    By layers1 in forum Samsung
    Last Post: February 9th, 2015, 07:44 AM
  5. Replies: 2
    Last Post: April 20th, 2010, 11:12 PM
