Results 1 to 2 of 2
Thread: GE PSCS5RGXAFSS compressor not starting
    Dec 2014
    utah
    Default GE PSCS5RGXAFSS compressor not starting
    Model Number: PSCS5RGXAFSS
    Brand: GE
    The compressor is not starting, replaced the board that plugs into the compressor with a working board, still not starting.* The strange thing is the digital display in front can toggle between "actual temp" and "set temp".* I set the "set temp" at 0 and 40, but the "actual temp" says "Freezer temp 0 degrees, refrigerator temp 65 degrees".* The fridge temp is 65 by my thermometer (also my garage's ambient temp), but the freezer is 65 too, not 0.*
    If both of those problems (compressor not starting, and "actual temp" reading inaccurately) are related, what would cause it?
    Oh, I ohmed and checked the compressor electrically, it is all fine.
    Thank you.
    Sounds like your motherboard is the culprit.
    Rick explains how to test to see if the inverter is the problem: FIXED GE Profile French Door Refrigerator Freezer Not working properly
    You will need a multimeter to do testing.
    Here's the motherboard for your model:
    GE WR55X10956 Main Control Board
  1. Amcor portable AC compressor not starting
    By LouK in forum Window & Room Air Conditioners
    Last Post: August 25th, 2016, 12:29 PM
  2. Compressor not starting
    By nd_rawlins in forum Amana
    Last Post: October 24th, 2013, 01:34 AM
  3. Compressor not starting
    By mskvarenina in forum Sears Kenmore
    Last Post: April 14th, 2013, 03:27 PM
  4. 106.7698380 Compressor has trouble starting
    By Andy54 in forum Sears Kenmore
    Last Post: July 20th, 2012, 01:58 PM
  5. Freezer compressor not starting - no cold air
    By scotty562 in forum Frigidaire/Electrolux
    Last Post: March 5th, 2012, 02:25 PM
