Results 1 to 2 of 2
Thread: SubZero 550 - Ice Maker not working (tried many other tips from the forum)
    Dec 2016
    Default SubZero 550 - Ice Maker not working (tried many other tips from the forum)
    Model Number: 550
    Brand: Sub Zero
    Age: More than 10 years
    I have a SubZero 550 that stopped making ice. These are the notes/results based on trying things I've read from other messages in these forums:
    - Ice feeler arm is locked in the up position
    - I've tried to force it down but it won't budge (and I don't want to break it)
    - Defrosted the freezer
    - When I restarted the fridge/freezer the water filled the ice maker
    - The feeler arm is still locked in the up position
    - There are 3 switches in the freezer. 1 for the light, 1 that turns on the freezer fan and 1 the ice maker tray closes
    - I taped the ice maker tray switch closed to force cycle (is this the only one that needs to be "closed?)
    - When it is taped shut the ice maker makes a "ticking" noise - I've checked a day later and it is still making the ticking sound but no ice has dropped and feeler arm is still up.
    - Tried to force cycle the ice maker (jumpering T and H for 10 seconds). There was a small spark so the jump was working but it made no effect
    I feel that the issue is around the feeler arm being locked in the up position but I don't want to force it down.
    Other thing I haven't tried yet is to reset the circuit breaker.
    Anything else I can try or do I need a new ice maker?
    Derek
    Jul 2006
    The Sub Zero ice maker 4202850 is no longer available. 4202850 changes to: Ice Maker 7002748
    I believe this one will work:
    You will need to use the old wire harness and shut off arm
    Ice Maker Assembly WPW10190965
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. 680/S SubZero Ice Maker - No Ice - need some troubleshooting help
    By Heynowjerry in forum Refrigerators & Freezers
    Last Post: January 11th, 2017, 09:37 AM
  2. ice maker leak-tips???
    By cstultz in forum Refrigerators & Freezers
    Last Post: July 19th, 2013, 06:34 AM
  3. Replies: 13
    Last Post: November 8th, 2011, 09:26 PM
  4. Microwave Using Tips
    By nancypeterson in forum Microwaves
    Last Post: July 30th, 2007, 05:31 AM
  5. buying used Kenmore, tips ?
    By gulleyj in forum Sears Kenmore
    Last Post: November 19th, 2005, 01:47 PM
