Results 1 to 10 of 16
Thread: WSF26C3EXB01 Side by Side Whirlpool Leaking from freezer door
    Jan 2017
    MO
    Default WSF26C3EXB01 Side by Side Whirlpool Leaking from freezer door
    Model Number: WSF26C3EXB01
    My fridge looks to be leaking from the water lines going up into the freezer door (photos attached). The fridge door (right door) does not have the rust and calcium build up like the left door. Before ripping the whole door apart to continue investigating, I am curious if anyone has seen the issue and may know how to fix it! Thank you in advance!!
ID:	31802 Click image for larger version.
    Jul 2006
    Check the ice maker and water valve. It's most likely one or the other:
    Whirlpool WPW10251076 Icemaker
    Whirlpool WPW10341320 Valve-Inlt
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jan 2017
    MO
    The ice maker still makes ice just fine so I wouldn't think it would be the ice maker itself. There has to be a leak somewhere in that door. Are there valves in the door? If so, how do I get to them?
    Jul 2006
    Doesn't your machine have the "In-Door" ice maker? Is the ice maker in the freezer section or on the left door?
    Jan 2017
    MO
    The ice maker is in the left door and the leak is coming from the hole where the water lines go up inside the door.
    Jul 2006
    If the water valve or ice maker which is located above the dispenser developes a leak the water can run down the hole for the water lines because the rest of the door is foamed in insulation.
    Jan 2017
    MO
    Understood now! Thank you for your replies, I will post back if it works.
    Jan 2017
    MO
    Quote Originally Posted by rickgburton View Post
    I am actually having issues locating the valve. I see it in the parts manual but it does not do a good job illustrating its location within the left door. Are you able to help locate on a diagram or picture where it is?
    Jul 2006
    OK, if you don't see the fill valve then it's located behind the machine and not in the door. Check the condensate drain.
Name:	GSF26C5EXS Water Line Route.jpg
    Jan 2017
    MO
    Not the drain. Do you have any diagrams on how to get to the lines going up inside the door? I can't seem to get to any valves inside the door or to check if the tubing cracked. I can feel the drip coming out of the hole in the bottom left corner of the left door where lines go up.
  1. Replies: 6
    Last Post: December 30th, 2015, 10:13 AM
  2. Replies: 3
    Last Post: September 1st, 2014, 11:58 AM
  3. Replies: 4
    Last Post: September 20th, 2013, 04:00 PM
  4. Replies: 1
    Last Post: March 2nd, 2013, 08:57 PM
  5. Whirlpool side-by-side refrigerator/freezer icemaker leaking
    By kiprhyn in forum Whirlpool/Roper/Estate
    Last Post: August 1st, 2012, 12:53 PM
