FIXED 592-49003 Kenmore Elite Washer leaking from...what is this? (pic)
Tim99
Edmonton, AB
Hey guys,
I have a leaky Kenmore Elite that's about 7 years old, model is listed as 592-49003 but I can't for the life of me find that model on any parts websites.
Leak is coming from the unit that the water lines come out of. Specifically, the nozzle which connects to the main water line. Drips about once every two seconds when the cold water is on and the machine is not running. Hoses are in good shape and as you can see in the pic, drip happens when hose is disconnected as well. None of the other nozzles on the unit are leaking.
Any help on what this thing is called and where a fella could get a new one, would be very much appreciated.
For the most part Canadian model #'s are not online...esp dept store brands.
Any numbers on that part?
Tim99
Edmonton, AB
Ahh, that explains it. Is there anywhere you know of that I can go and find the corresponding US model #?
No model number on the part that I am able to see, unfortunately. Attached a couple more angles of it in case its of any help.
Tim99
Edmonton, AB
Update: Part number was visible after removing (DN06 23 D) and apparently it's an inlet valve. No luck finding a replacement online, however.
I doubt there is one.
(DN06 23 D)
Yes it appears to be a fill valve....but that does not look like any part#.
Some common one for an Samsung built Kenmore are linked here.....with pictures.
