596.75523400 Programming Jazz board
Brianswensen
California
I replaced a jazz board (WPW10503278) for a refrigerator not defrosting. This model has a program code of 12. When I try to program the board the highest it goes is 8 or 9. I set it to 8. Will this be ok or should I be setting it to a different number? Thanks!
I don't think you're programming it right. If the program code is 12 on the model/serial tag
Open the Fresh Food door and hold the Fresh Food door light switch closed while pushing the Freezer Temperature Down (-) Key pad 3 times consecutively.
Release the Fresh Food door light switch.
The control will display PE to confirm entry into the programming mode.
Press the Freezer Temperature Down (-) Key
Press the Freezer Temperature Up (+) key until "1" is displayed in the freezer display
Press the Refrigerator Temperature Up (+) key until "2" is displayed in the refrigerator display
Press the Freezer Temperature Down (-) key and hold it until the "1 & 2" start flashing
Close the refrigerator door.
