Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: FIXED: NX58F5500SS Samsung gas range control panel not responding
  1. #11
    Sep 2017
    NJ
    Quote Originally Posted by rickgburton View Post
    OK, the problem is in the control then. If you got the keypad from the link I gave you, you can return it for a full refund less shipping. Here's the control:
    Control Board DE92-02588G
    Attachment 35273
    That is also good for the NX58F5500SS, it looks like mine has more plugs then the picture.
  2. #12
    I looked it up by model number
  3. #13
    Sep 2017
    NJ
    Hi Rick, I'm guessing that's a yes, it's good for my stove. Thanks
  4. #14
    Nov 2017
    Houston
    Quote Originally Posted by nbenitez View Post
    It was the keypad. Replaced it and now everything is working fine.
    Nelson
    Hi Nelson,
    Can you show me where and what is the detail of keypad did you buy to replace it? I had the same Range model and problem like you.
    Thank you,
    Sakula
  5. #15
    Sep 2017
    NJ
    Sakura,
    If you go back in the thread posts you'll see the part number From Rick, I also replaced the control board and mine is working fine.
    Al
  6. #16
    Nov 2017
    Central Illinois
    We have the same model of Samsung range. The display on ours is completely blank with no display. We still have power going to the igniters for the stove top, but display is out and cannot use the oven. Any suggestions? Thanks.
  7. #17
    Look on the back of the board for the L1 connector (should be marked on the board) Measure the voltage between L1 and N. If the voltage is 120 VAC replace the ERC.
  8. #18
    Dec 2017
    Massachusetts
    We are also having the same issue with our 3 year old NX58H5600SS. AT first, it was displaying the -SE- error on the display. It was doing this intermittently, so sometimes the keys would work fine. After looking up the causes, it sounded to me like a bad keypad.
    I replaced the keypad and it still kept displaying the same error. However this time, the error code never went away, nor did the keys ever work - even after reseating the ribbon cable several times, to no avail.
    Next up, I figured it was the PCB. So I replaced this also - no difference at all. It is still displaying the -SE- error and none of the keys respond.
    Is there anything else here this could possibly be? Could it be the harness? It doesn't seem like this could be the cause to me, but I'm not an expert. Is it possible that the replacement keypad is defective?
  9. #19
    Quote Originally Posted by qbarrel View Post
    That would be my first guess. Is this the one you replaced?
    DG34-00027B Switch MEMBRANE
  10. #20
    Dec 2017
    Massachusetts
    That's the one. Of course now that it's already been installed and adhered to the subplate I won't be able to return it. I hate to keep throwing money down the hole here, but it might be prudent to order another one. I guess the PCB could be returned though.
    Is there anything else you can think of that it might be?
  1. Samsung range, Control panel blinking
    By Smathew1 in forum Ranges/Ovens
    Last Post: April 4th, 2017, 10:16 AM
  2. 596.76572600 Control panel buttons not responding
    By jalashkar in forum Sears Kenmore
    Last Post: January 25th, 2017, 06:03 PM
  3. Replies: 4
    Last Post: January 29th, 2016, 05:44 AM
  4. Control panel not responding
    By redmagiq in forum KitchenAid
    Last Post: July 8th, 2015, 09:45 AM
  5. Maytag MDB8949SAM0 control panel not responding
    By Reidkon in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 22nd, 2014, 09:14 PM
