Results 1 to 10 of 10
Thread: IMQ225300 Inglis side x side Fridge freezer ice maker area freezing up
    Nov 2011
    BC,Canada
    Default IMQ225300 Inglis side x side Fridge freezer ice maker area freezing up
    Model Number: IMQ225300
    Age: More than 10 years
    Hi all....been awhile since I posted but have a problem that's suddenly started. The area in the freezer around the the ice maker and tray that holds the ice has begun freezing up with ice...when cleaned out, by the next day the same thing has happened. The freezer is set at just over B. Anyone any ideas as to what might be causing this and if it's repairable?
    Thanks for any help.
    Jul 2006
    Check to see if the ice door flapper is closing all the way.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    BC,Canada
    Thanks Rick....where would I find the door flapper?
    Nov 2011
    BC,Canada
    Sorry Rick....had a blonde moment....the door flap between the ice maker and the chute
    that delivers the ice seems closed.
    Jul 2006
    When you say freezing up with ice, is it ice, frost or snow? Any chance you can take a picture and post it here?
    Nov 2011
    BC,Canada
    Thanks Rick....here's some photos. Sorry for duplicating.
ID:	33960Click image for larger version.
    Jul 2006
    The door is not sealing on the top left corner. There's an air leak. Both doors closed: Is the freezer door sitting lower than the fresh food door? Is the space between the two doors the same on the top and bottom?
    Nov 2011
    BC,Canada
    Freezer door sitting very slightly higher than fridge door, but has been this way since we moved into the house. Gap between both doors seems the same. So what would you suggest to resolve this....a new seal ?
    Jul 2006
    Check the seal all the way around the door and make sure it's intact and not torn anywhere:
    Door Gasket 2159072
    Nov 2011
    BC,Canada
    Thanks Rick....sorry for the delayed response. Checked the gasket and there's a small tear in the bottom corner and also some frosting there. The top corner that you identified seems very soft. I have ordered a new gasket but it will take 3 to 4 weeks to arrive.....is it okay to use the freezer until it gets here?
ID:	34011Click image for larger version.
  1. Replies: 3
    Last Post: May 14th, 2017, 06:21 PM
  2. Replies: 20
    Last Post: September 15th, 2015, 09:20 AM
  3. GE Side by Side fridge side cold, freezer not freezing
    By Girlscout58d in forum GE/Hotpoint
    Last Post: September 18th, 2013, 12:05 PM
  4. Replies: 11
    Last Post: April 26th, 2012, 05:45 PM
  5. Replies: 1
    Last Post: July 13th, 2009, 12:28 PM
