Results 1 to 4 of 4
Thread: Sub Zero 601F won't stop icing up
    Sep 2017
    Seattle, WA
    Default Sub Zero 601F won't stop icing up
    Model Number: 601F
    Brand: Sub Zero
    Age: More than 10 years
    I've got a set of Sub Zero 601R and 601F that I've owned since the house was new in 1999. The 601R (fridge) has been bulletproof. The 601F (freezer) has been great... with the exception of having to completely defrost it about once a year. I keep the condenser vacuumed. I make sure the drain is clear (until it ices up). I've replaced the control board. I've replaced the drain heater. It just keeps icing up.
    There's got to be something I'm missing. Any ideas of what else I can look for or check?
    Jul 2006
    Where exactly is it icing up?? "Once a year" is an odd time. If the evaporator was icing over it would be more often than once a year. OK, I read it again and assume you're talking about the defrost drain under the evaporator. Is that correct?
    Last edited by rickgburton; September 5th, 2017 at 02:57 AM. Reason: added more info
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2017
    Seattle, WA
    Quote Originally Posted by rickgburton View Post
    Yes, it's the evaporator, and it ices up more than once a year... that's just how often I've been feeling motivated enough to empty it out, pull off the rear panel, and defrost everything.
    The ice seems to start forming near the bottom of the evaporator and then fills the defrost drain. I've replaced the control board, thinking perhaps it wasn't properly initiating the defrost cycle. I've been chasing this problem for years, and keep coming up empty.
    I know there's a way to manually initiate the defrost by holding down the ICE button while the unit is running, but I don't even know if that's the issue. I'm about to empty the unit and defrost it again, but I'd love some guidance as to how/what I should test to find the cause. Voltage on the heat strip? Something else I can test to see why it keeps icing up?
    Jul 2006
    To initiate Diagnostic Mode, the unit must be ON. With the unit ON, press and hold either COLDER key, then press the UNIT ON/OFF key, then release both keys.
    When initiating Diagnostic Mode, numbers may appear in the left display area with “EC” in the right display area. “EC” indicates the numbers at left are an “Error Code”
    If no error codes are registered, the left display area will show the real-time temperature of the thermistor being read, the right display area will show the thermistor location code, and all annunciators will illuminate on the LCD indicating the unit is in Diagnostic Mode.
    Pressing either COLDER key or either WARMER key while in Diagnostic Mode will toggle to the next or previous thermistor location, respectively.
Name:	error codes.jpg
ID:	35093Click image for larger version.
  1. Sub Zero 550 icing up
    By ZT mech in forum Refrigerators & Freezers
    Last Post: August 14th, 2016, 12:07 PM
  2. FIXED: Evaporator icing up
    By brian93 in forum Frigidaire/Electrolux
    Last Post: July 30th, 2013, 11:01 AM
  3. Ice Mkr Fan Icing & 1F Code No Fix??
    By Quadsteer in forum Sears Kenmore
    Last Post: March 22nd, 2011, 02:37 PM
  4. Sub Zero Icing Problem
    By misterg16 in forum Refrigerators & Freezers
    Last Post: May 15th, 2008, 12:05 AM
  5. Fridge icing up
    By FrozenFreddy in forum KitchenAid
    Last Post: July 23rd, 2006, 01:43 AM
