630.12243317 Kenmore side leaking into Dishwasher
zappy
canada
Good day,
I noted the bottom of my dishwasher was filling up with water and ended up spilling out. I assume it was my pump but once the dishwasher was turned on and put into drain mode all the water was gone. I then noted again this morning after running it there was no water but hours later it was filling up. I then noted there was a cover on the side of the dishwasher and water was slowly leaking it from there even though the dishwasher wasn't on. I've attached photos as I have no idea what this part of the dishwasher does and how to have the water stop leaking it from that part.
Thanks for any help.
I can't get this model# to work for me.
Might be because it is Canadian?
630. is a Bosch built Kenmore
This usually indicates the fill/inlet valve is not 100% shutting closed and some fill water is weeping into the d/w = new fill valve time.
LINK> Bosch/Kenmore Dishwasher Water Inlet Valve Parts
jeff sr.
