Results 1 to 3 of 3
Thread: GT19DKXJT00 Compressor not starting
    Nov 2017
    Pennsylvania
    Default GT19DKXJT00 Compressor not starting
    Model Number: GT19DKXJT00
    Compressor: Matsushita DA51C72RCU6
    The refrigerator stopped keeping things frozen. The compressor does not seem to be starting and gets hot. The 3 contacts on the compressor all give an ohm reading between each other, and each contact does not give a reading when testing for a short using a scratched area of the compressor. I tested capacitance and the farad reading was 2% above the listed value on the capacitor. I thought this meant a bad relay, so I bought a Supco RCO410 and followed the instructions to wire it up to the compressor. However, it still is not starting and still gets hot. I did hear it try to start once though, but it was a split second and I can't get it to do it again. Did I misdiagnose, or did I get the wrong 3 in 1? This was my first time working on a fridge, though I spent many hours trying to learn, I may be overlooking something simple. Thank you all for any help and advice.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	35507   Click image for larger version.
    Oct 2004
    Why was that?
    Compressors are an electrical motor AND mechanical pump all together.
    Shouldn't be using a 3-1 in most modern compressors!
    Sounds like the compressor is mechanically seized up = new compressor or new refrigerator time.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Yeah I've got O.C.D.....Old, Cranky and Dangerous.
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Jul 2006
    OK my friend, when checking the compressor:
    First check for 120 VAC across the two wires going to the compressor. If the voltage is correct unplug the machine and remove the relay/overload/start device from the compressor. The overload should show continuity. The relay should show 3-23 ohms. The capacitor is a run capacitor. It's not necessary for the compressor to run properly. The compressor is a 1/16 hp. The 3-N-1 you installed is too big (1/4-1/3 hp) and it uses a start capacitor. A start capacitor will destroy any circuit boards in the machine and will eventually kill the compressor. If the relay and overload check good measure the compressor windings. These should help:
Name:	R -Compressor Windings Test.jpg
ID:	35522Click image for larger version.
Name:	R -Relay Overload Start Device.jpg
    - - - Updated - - -
    oops, sorry jeff1
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. GD25DFXFW02 Compressor not starting
    By kscheer in forum Whirlpool/Roper/Estate
    Last Post: August 18th, 2017, 09:12 PM
  2. GE PSCS5RGXAFSS compressor not starting
    By billionj in forum GE/Hotpoint
    Last Post: November 21st, 2016, 06:00 PM
  3. Compressor not starting
    By nd_rawlins in forum Amana
    Last Post: October 24th, 2013, 01:34 AM
  4. Compressor not starting
    By mskvarenina in forum Sears Kenmore
    Last Post: April 14th, 2013, 03:27 PM
  5. Freezer compressor not starting - no cold air
    By scotty562 in forum Frigidaire/Electrolux
    Last Post: March 5th, 2012, 02:25 PM
