Results 1 to 8 of 8
Thread: 253.58087894 2 day refrigerator death
    Jan 2018
    Lehigh, FL
    Default 253.58087894 2 day refrigerator death
    Model Number: 253.58087894
    Day one fridge ran fine. Cleaned entire fridge then took it outside to blow out coils etc. Plugged fridge in and popped GFCI. Unplugged one component at a time until power stayed on. It seemed to be the ice maker. Plugged into non GFCI with ice maker plugged in and it ran but would get little shocks when touching anything metal on machine.
    Day two unplugged the ice maker and ran it from a non GFCI outlet, no shocks. It ran about 5 hours and popped the breaker. I unplugged one thing at a time and it popped until I unplugged the large 2 piece square plug that has 9 individual wirers coming from it but then only the interior lights would work. Also I would get the same result if I plugged in the large square 2 piece plug but had the freezer control in off position. It would pop the breaker if I moved it to the on position. I don't know why it went from running fine to running with the ice maker unplugged to running on a non GFCI plug to not at all. I also changed the thermostat and jumped the safety switch. With my limited knowledge I'm stuck. Any ideas what to do next? Thanks.
    Check the compressor windings and the relay/overload for a short. Here's how:
Name:	R -Compressor Windings Test A.jpg
ID:	36373Click image for larger version.
    Jan 2018
    Lehigh, FL
    Thank you Rick, I will try that and get back to you.
    Sounds good. Keep us posted.
    Jan 2018
    Lehigh, FL
    Ok I took the readings. On the compressor I got 6.1 between C & S and 3.6 between C & R. On the start device I got 6.1 between R & S and 0 between C and the terminal on the front. What's my next step. Thanks
    Quote Originally Posted by sanraven
    What plug is this? Use an amp meter and monitor the amps when the machine is running.
    Jan 2018
    Lehigh, FL
    Here's some pictures of the plug by the fan motor, that I'm referring to, and the wires coming from it wrapped around the Freon tube going up the back of the fridge. I'm sure I'm not being clear but at this point if I connect everything back up and attempt to plug the fridge in to a non GFCI outlet it will immediately blow the breaker, so it would be impossible to monitor the machine while it's running. Maybe there's a short in a wire so I will thoroughly inspect each and every wire I can get to. I appreciate all the help you are trying to give me.Click image for larger version.
ID:	36407Click image for larger version.
ID:	36408Click image for larger version.
    Oh OK, if it trips the breaker immediately there's a direct short to ground somewhere.
  1. Kenmore 80 Series Death Shakes
    By vortex2450 in forum Sears Kenmore
    Last Post: February 6th, 2013, 09:14 PM
  2. FIXED: 3 Beeps of Death
    By mji1010 in forum Sears Kenmore
    Last Post: January 18th, 2012, 12:37 PM
  3. Kenmore 80 Series Washer Death?
    By melissafaith in forum Sears Kenmore
    Last Post: October 17th, 2011, 05:30 PM
  4. Are we responsible for our Frigidaire's death?
    By FLCube in forum Frigidaire/Electrolux
    Last Post: August 31st, 2011, 02:37 PM
  5. Death, Taxes and the F-01 Error Code
    By EllisU in forum Whirlpool/KitchenAid Reviews
    Last Post: January 21st, 2011, 09:37 PM
