April 16th, 2018, 08:01 AM
#1
Trying to install drain pump (UPK3) in a GE icemaker (UCC15NJBII)
Brand:
GE
Less than 1 year
I am trying to install a drain pump (UPK3) in a GE icemaker (UCC15NJBII). The instructions are not clear. They state:
H.Trace the black and white power cord from the switch assembly to the black and white power cord coming from the unit near the compressor. Make sure that the wires lay on the left side of the pump if you are facing the unit from behind. Unplug the current black and white wire’s connection. Plug the black and white wire’s connector from the unit into the black and white connector from the switch assembly. Repeat with the red and white connections. It is not necessary to replace the wire tie that is removed to disconnect the connector. Connect the 3-pin connector from the switch assembly bracket to the 3-pin connector on the pump.
I am confused where it says 'Repeat with the red and white connections'. There is no other red & white connector. Presumably they mean: 'Attach the drain pump wiring by firstly disconnecting the current black and white power connector from the black and (2) white wire connector from the unit near the compressor. Then connect the (2) black and (2) white wire connector from the drain pump switch assembly to the black and white wire connector going to the power cord. Then connect the red & white connector from the drain pump switch assembly to the black and (2) white wire connector from the unit near the compressor.'
Is that correct?
By theman in forum Undercounter / Freestanding / Stand Alone Ice Makers
Last Post: December 23rd, 2017, 10:18 AM
By mexico in forum Undercounter / Freestanding / Stand Alone Ice Makers
Last Post: May 22nd, 2012, 07:57 PM
By DaveBry in forum General Appliance Chat
Last Post: June 3rd, 2011, 08:29 PM
By ddonlon in forum Sears Kenmore
Last Post: June 8th, 2010, 11:41 PM
By Bambiblaster in forum Sears Kenmore
Last Post: April 18th, 2007, 06:27 PM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
