Thread: SG4990W - speed queen - motor installation wiring help
    Bedford ohio.
    Default SG4990W - speed queen - motor installation wiring help
    Hello all!
    I come here out of desperation, I'm trying to fix my mothers dryer, its a speedqueen like in the title.
    The repair was going smoothly until i had to actually wire the new motor into the existing connections, i took pictures of all the stuff i unplugged. The actual problem was the wiring instructions i got, they said just match up the colors and good to go. I got off the harness
    1 pink and yellow spliced together
    1 white with orange spliced off of it.
    1 orange
    1 brown
    1 orange off the white splice.
    Total 5
    For the adapter harness's i got 2 different options.
    One with 4 connections and one with 5.
    Adapter 1 is 4 connections
    1 brown
    1 orange
    1 white
    1 yellow
    Adapter 2 is 5 connections
    2 black connections
    1 yellow
    1 white
    1 brown
    Which should i use? And should I ignore the spliced together connections?
    1 has correct color just not 1 orange and the other has wrong colors but right number of connections!
    Sorry for the long post. I don't know if I'm allowed to post pictures or how....
    SG4990W is not pulling up as good, please recheck your model number.
    What was the problem with the dryer to make you replace the motor? You shouldn't have to rewire anything, it should be plug and play.
    Bedford ohio.
    Sorry if the model seems incorrect, but i took picture of the model label under the dryer door.
    In my above post, the connections are either too little or not the correct colors.
    Is there a way to post pictures on this forum? I can show you exactly what i mean.
    To upload photos--->Just Click "Go Advanced" at the bottom right side of this Quick Reply editor that we type in, then you will see the MANAGE Attachments Button.
    Again, what was the problem with your washer to make you change the motor???
  1. speed queen drive bell installation
    By glc4122 in forum Washers
    Last Post: July 26th, 2009, 10:58 AM
  2. Speed Queen won't spin
    By Mike CT in forum Washers
    Last Post: August 7th, 2007, 06:05 PM
  3. speed queen
    By beaser in forum Washers
    Last Post: September 28th, 2006, 04:28 PM
  4. Speed Queen washer motor jam
    By hvtc in forum Washers
    Last Post: November 16th, 2004, 10:33 PM
  5. Speed Queen Appliances
    By Jake in forum Maytag/Jenn-Air Reviews
    Last Post: October 10th, 2004, 07:16 PM
