Thread: FIXED: DV400EWHDWR Samsung dryer starts spinning and stops 5 seconds later
    May 2018
    FL
    Default FIXED: DV400EWHDWR Samsung dryer starts spinning and stops 5 seconds later
    Model Number: DV400EWHDWR
    Hello,
    The dryer started this yesterday out of nowhere. First it wouldn't even spin and just make a humming noise when turned on and started on cycle. I opened and cleaned the ducts and everything was clean. I tried helping the drum roll by pushing it while it was ON and it started but stopped completely after 5 seconds, but stays with power.
    If left in the cycle it will turn on and off now. I did notice that for being on 5 seconds the, what i assume is the motor, gets pretty hot.
    Anything will be helpful. My warranty just expired too.
    Thank you.
    The problem is your motor went bad. Make sure you unplug your dryer before replacing it.
    Here's the motor for your model you can order:
    Drive Motor DC31-00055D
    This video shows you "how to" replace it: Samsung Dryer Drive Motor Replacement Video
    May 2018
    FL
    thank you. i will keep you posted. *crosses fingers*
    In the dryer the model has an /AA (DV400EWHDWR/AA) at the end, does that matter or is it the same motor from above?
    Its the same motor with the /AA at the end too.
    I double checked that yesterday.
    Yes, please keep us posted.
    May 2018
    FL
    Replaced motor this weekend and works like new now. Still not sure what would cause it to just break after 2 years but I'm glad it's fixed, hopefully for a while.
    Thank you Jake!
    Excellent Elenar good job, glad to hear that.
    Yes, that's a mystery to me too, I've seen some go 10 years and some 2 years, seems to be no rhythm or reason why some only go 2 years.
  1. Replies: 15
    Last Post: June 16th, 2018, 10:15 AM
  2. Replies: 7
    Last Post: April 12th, 2018, 04:36 PM
  3. FIXED: Washer Makes Loud Noise. Starts spinning then stops. Lift lid then starts spinning then stops?
    By brmommy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 20th, 2014, 06:58 PM
  4. FIXED: PYG1000AWW Dryer Motor Starts for 2 Seconds Then Stops
    By kingamoon in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 5th, 2014, 08:28 AM
  5. Dryer Starts, Stops after a few seconds
    By sosinc3 in forum Sears Kenmore
    Last Post: October 10th, 2006, 02:22 AM
