Results 1 to 5 of 5
Thread: LG Washer WT5001CW Grinding noise with UE and Dr Error Codes
    Oct 2013
    NC
    Default LG Washer WT5001CW Grinding noise with UE and Dr Error Codes
    Model Number: WT5001CW
    Hello,
    My LG Washer is making a horrible grinding noise and it appears to be stuck in a fill doom loop and never completely drains, even when it is set to Spin Only - it just refills. I have had error codes UE and Dr. Link to video below. Any suggestions greatly appreciated. Thank you.
    https://streamable.com/24933
    Oct 2013
    NC
    Default Update
    Correction: I am getting Error Codes LE and Dr (not UE).
    Error Code Dr=Door switch, that will need to be replaced.
    Here it is for your model:
    EBF61674802 Switch Assembly
    Here's the video to show you how to replace it: Door Switch Video
    Here's the service manual for your model: https://www.dropbox.com/s/ttlat778nj...anual.pdf?dl=0
    Page 35 explains what error code LE is and what to test.
    What you mentioned about it not draining properly, I'd first check for something inside the drain pump that could be partially clogging it up. If the machine doesn't drain properly that maybe why its constantly trying to fill, thinking the water is all drained out already.
    Remove the rear access panel and look in the drain pump:
    5859EA1004E Pump Assembly,drain
    For that noise problem, move the tub around and see if it makes that same noise, when did that noise start?
    Oct 2013
    NC
    Thanks Jake! The noise started one wash load before this one and while it made noise, it completed the cycle. One wash later it was not working properly. Moving the tub around does not replicate the noise. The noise comes from when the agitator or whatever it is called on the bottom of the tub spins (or tries to spin).
    Ok, Got it!
    If your drain pump is fine, nothing clogged in it, then Page 35 in the service manual I posted above will tell you what to do to fix it.
    Here's the parts diagram for your model: LG Washer WT5001CW / Repair Parts
  1. Maytag washer grinding noise
    By rdlammons in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 20th, 2016, 08:51 PM
  2. LG WT5001CW whinning noise and not slow spin
    By nece1117 in forum Washers
    Last Post: September 6th, 2012, 06:00 AM
  3. cabrio washer f70 f32 f50 f80 error codes
    By John0306 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 14th, 2008, 08:56 PM
  4. kENMORE hE4T Codes / WHirlpool Duet Error Codes Link & f02
    By Tryspammingme in forum Sears Kenmore
    Last Post: April 30th, 2006, 11:00 AM
  5. Duet washer Error Codes & F02
    By Tryspammingme in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 30th, 2006, 06:39 AM
