Thread: WM3670HWA LG Washer 120 volts on both sides of coil of water inlet valve
    Bradenton
    Default WM3670HWA LG Washer 120 volts on both sides of coil of water inlet valve
    Model Number: WM3670HWA
    Age: Less than 1 year
    Getting 120 volts to the coil on the water inlet valve. Iím getting 0 volts while connected is plugged in and that is from one side of the coil to the next this would indicate that power is passing since only 0 volts are detected problem is that the inlet valves are not seeming to run at those times and other times it does. Anyways the initial complaint is that it doesnít seem to fill with a lot of water she had an older model top loader previously. Any ideas?
    Quote Originally Posted by Jeffv1982
    I’m getting 0 volts while connected is plugged in and that is from one side of the coil to the next this would indicate that power is passing since only 0 volts are detected problem is that the inlet valves are not seeming to run at those times
    I have no idea what you're trying to say in that sentence but this is you answer: Front load washers use around 12 gallons of water. Top load washers use around 25 gallons of water.
  1. Replies: 7
    Last Post: June 14th, 2018, 04:42 PM
  2. Replies: 1
    Last Post: June 5th, 2018, 10:38 PM
  3. WTW5590VQ1 Washer does not fill with water; new inlet valve makes clicking sound
    By jpg90 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 31st, 2017, 09:09 PM
  4. Water inlet valve coil keeps burning out
    By Wayneboy in forum Sears Kenmore
    Last Post: August 4th, 2013, 09:12 AM
  5. Replies: 3
    Last Post: February 4th, 2013, 12:29 PM
