Thread: DLG5988B LG dryer hums, starts manually
    San Diego, ca
    Default DLG5988B LG dryer hums, starts manually
    Model Number: DLG5988B
    I have an LG dryer that sometimes starts fine, and sometimes hums instead of starting. When it hums, you can start it manually by opening the door, press the door sensor, start button, and then manually start the drum spinning when it hums. Once you do this you can release everything, close the door and it will start fine again.
    This happens about half the time. Iíve seen some posts about bad motors with the humming sounds but wondering if itís something else because I can still start it manually.
    Thanks for your help
    Clean out the motor and motor switch with compressed air if available. If not, vacuum it the best you can. There could be lint build up around the motor switch keeping it from closing every time. If not here's the motor you need:
    Drive Motor 4681EL1008A
  1. Replies: 3
    Last Post: April 29th, 2018, 11:32 AM
  2. Washer hums no spin, no drain or starts a cycle
    By Veronica87 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 9th, 2016, 02:09 PM
  3. Dryer emits buzzing sound; belt OK; burning smell when manually turning drum
    By socaluser in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 20th, 2016, 07:58 PM
  4. Replies: 4
    Last Post: January 13th, 2014, 09:24 PM
  5. FIXED: Dryer not starting - heard a clack sound when moving drum manually
    By ashuman in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 21st, 2009, 12:16 AM
