FIXED 665.12776K310 Kenmore Elite Dishwasher extremely hot water/ stuck in a cycle
laurent
Chicago
665.12776K310
Model: 665.12776K310
Hello Everyone,
My dishwasher is about 7 years old and we use is very frequently at least once a day. Last year, I had to replace a top rack plastic bracket with the metal one and later the diverter seal because it was leaking.
Since about February 2021, I caught the dishwasher stuck in a cycle (sometimes 1-hour or Normal wash) for more than 8 hours. When I opened it, the water was filled quite a bit at the bottom. I could almost hear something that is trying to process something but stuck in a loop. After experiencing that twice, I reset the power breaker and it went away. Then, I started noticing more and more hard plastic cup/plates melting. The steam was so hot that the bottom of the countertop where the vent is started to drip and bubbled up the cabinet panel. Resetting the power breaker didn't help and instead, I am now experiencing the machine getting stuck again and extremely hot water. What is frustrating is that sometimes it ran the cycle normally.
Questions:
1. Since this is a panel ready dishwasher, I ran the diagnostic but how can I see the codes if there isn't anywhere to display it? The diagnostic completed successfully I believe
2. What is causing the water to go super hot randomly? My water boiler produces heat at about 110 Fahrenheit
3. What is causing the machine to randomly stuck in a cycle?
4. Also, in the attached video, I am noticing the humming noise getting louder then it should (minus the water sound). Is this a sign of motor going bad?
I'm attaching your tech. data sheet below, Look on page 6--->Service Diagnostics with Error Codes
Your model may have the Complete LED instead of Clean LED.
The Clean (or Complete) LED will flash the error codes in two parts. The Clean (or Complete) LED will first flash the function code, pause for 2 seconds then flash the problem code, pause for 5 seconds then repeat three times (unless advanced by the Start key to the next interval). If there are no error codes the Clean (or Complete) LED will stay on solid for 5 seconds.
Let us know what error code/codes you get.
In the video is it in the wash cycle or drain cycle? I'm not sure where that humming sound is coming from, possibly from the wash motor or diverter motor if its in the wash cycle.
By the way, please update your last thread from 2018 here:
So we will know what fixed it.:)
  • Tech Sheet - W10543820 - Rev B.pdf
laurent
Chicago
Thanks Jake. I updated the other post, nothing was done to the freezer.
As far the the dishwasher goes, I got error codes below:
9-1
3-2
6-4
9-2
Fyi; The dishwasher itself is pretty level all throughout. I'm not sure how to enter the service cycle diagnostic, if I leave it at normal and high temp cycle and close the door, it will start running. In the video I posted previously, after entering 123 sequence 3 times,I shut the door and it started running.
I also normally do Normal cycle washer without any options.
9-1--->Diverter Can't Find Position
3-2--->Thermistor/OWI Shorted
6-4--->Float Switch Open
9-2--->Diverter Stuck Open
In the tech. data sheet do exactly what it says to check for each error code.
For the overly hot water, that would be 3-2--->Thermistor/OWI Shorted. Check for shorted wires at the heating element and at the Thermistor/OWI.
Here's the Thermistor/OWI for your model you can order, if no shorts are found:
Turbidity Sensor WPW10705575
To run the SERVICE DIAGNOSTICS CYCLE:
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
laurent
Chicago
Thanks, it doesn't look like there was any shorted wires. I'm going to replace that component and report back after running the Service Diagnostic Cycle.
I gave it a run yesterday with Normal cycle and High Temp wash option which I normally don't do. I stopped it after the wash cycle went on to 5 hours mark, it was still splashing water right before I opened the door. The steam was not as burning HOT as when it was melting plastics away.
Ok sounds good, let us know how it goes after you replace the OWI Turbidity Sensor.
laurent
Chicago
Well, I replaced the OWI Turbidity Sensor today and ran the service diagnostic cycle. Once it completed, I ran the 123 sequence again, close and open door. All lights stayed solid, tried again...still the same, all lights were solid, which is good.
I ran a normal cycle without any options as usual. It completed in 2 hours! I thought it takes about 3 to 4 hours?
The only different was that I didn't use dishwasher pod,I poured the powder detergent instead since I find it more gentle on the machine. I will try the pods again and see how it behaves and report back in a week.
Note:
When removing the sensor, make sure to have a rag to catch the water flowing out..it was quite a lot of water for me.
Excellent, sounds like your making good progress.(y)
We recommend using Cascade detergent, lots of times non-name brand or store brand detergent is not up to par and can muck up the inner workings of the dishwasher.
