665.12793K311 Kenmore Elite Cycle Issue - Dishwasher will stop during the cycle and you need to press start again to restart
Trixie12
Oregon
665.12793K311
Hello There,
Have a question about this dishwasher. Just started today during a cleaning cycle. The dishwasher will stop during the cycle and you need to press start again to restart. All panel lights start blinking as well. Will only run for a brief amount of time before repeating the issue over again. Happens with every cycle. Smart wash, quick rinse, normal cycle. I don't know the age of this machine as it was here when we moved in.
Been reading other posts here and have not found an answer.
Don't wish to start replacing parts until I know what exactly is causing the issue.
Appricate any help anyone can provide.
Your model has the problematic door vent that can cause this issue.
Do this first--->Disconnect all the wire connectors to your door vent and see if it runs through a complete cycle.
Start reading what bigbuck said at post#18 here:
Your model uses the exact same door vent. If it runs through a complete cycle and everything is back to normal, then order and replace the door vent assembly.
WPW10469574 Vent
To access the vent assembly you will need a T-15 torx screwdriver: Remove 4 screws (long) across top of door, then remove 10 screws (short) on the sides, then the outer door panel pulls off.
Trixie12
Oregon
Jake & Bigbuck,
Thanks for that information. Disconnected that wire today and closed everything back up. Dishwasher is running just fine now thru the normal cycles. Will order that part and replace it. I'm thinking the filter also needs to be changed also. Does anyone know the correct part number?
Excellent, glad to hear its running through the complete cycle once you disconnected that door vent wiring. Yes, the new door vent will fix it.:)
Here's the filter for your model you can order too:
Pump Filter W10872845
Let us know how it goes when you get the new door vent installed.
