665.13193K902 Kenmore Dishwasher leaking
Sawyer
Virginia
665.13193K902
The dishwasher is leaking on the left side in the front under the door. I have replaced vent seal, but leak continues.
Corrected model number
665.3193K902 doesn't pull up as good, please recheck your model number.
Remove the lower spray arm and check for cracked or splits in it, that would also cause this problem.
Here's the lower spray arm for your model:
--->To remove the spray arm, there is a lock nut directly underneath the spray arm that will need to be rotated counter clockwise in order to remove the spray arm.
Sawyer
Virginia
I have removed the spray arm and did not see any cracks or splits. Major leak is left side.
Is the leak coming down from the door to the bottom? Have you checked your detergent dispenser?
Look at this thread:
Your model uses the detergent dispenser--->WPW10195175
