665.13222N412 Wash Motor Won't Start - F8 Fuse 33 Ohms
KenmoreIssue
OR
665.13222N412
Wash motor stopped running. I've got the front pulled off. I tested F8 using the front leads and it read 33 Ohms which I believe means it needs to be replaced. Where is the motor fuse???? I tried to track the lead wire but that wire harness is confusing.
There is no motor fuse.
Yes, It's most likely a bad wash motor, this has become a common problem as of late, many members here have reported the same. In fact I had 2 this past Sept. 2018 in Parker, Arizona that did the exact same thing, and the new wash motor fixed them both.:)
I'd first check to see if your getting 120 volts to the wash motor when it should be in the wash cycle. His Kenmore 665 model uses the exact same wash motor yours does.
Take the wire connector off the wash motor and use your multimeter to see if yours is getting 120 volts when it should be washing, if so and it's not running order the wash motor below.
Here is the wash motor assembly you can order:
W11032770 Motor-Pump
Here's the video to replace it:
