665.13262K113 Kenmore dishwasher clicking
danclow
carbon alberta
665.13262K113
My kenmore dishwasher will fill then sit there and click, it starts runing after I pull it out and knock on the motor
lately it has been making sounds like it has been labouring as well
Sounds like your wash motor is bad.
We have been having quite a bit of these wash motors failing as of late, I'd recommend using a multimeter and set it on AC volts and removing the electrical connector to the wash motor and putting the multimeter probes in it, when the wash motor won't run, and see if you have 120 volts to it, when it should be running.
If the 120 volts is present, then its a bad wash motor.
Here's the wash(circulation) motor for your model, you can order if needed:
WPW10510667
There is a video in the part link that shows how to replace it.
RepairClinic ships to Canada:
Circulation Pump WPW10510667
