FIXED 665.13409N412 Kenmore Dishwasher Sanitize flashing
katzman299
Kansas
665.13409N412
Ran the dishwasher on smartwash with sanitize only. When done, has complete with sanitize flashing. The error codes were F-E- showing with Normal Cycle and 1 hour wash. After that, normal wash was lit and Turbo-heat Dry was lit. (lights under those selections) Water temp at the faucet is 135 degrees.
Hi Steve,
Please update your thread here first:
That may help us determine the issue now.
Thanks for updating it.
I don't have the tech. data sheet for this model, I will ask our tech bigbuck if he does to get to this new problem of Sanitize flashing when done.
I don't see F-E- either.
I'm attaching your tech data sheet below that bigbuck gave me.
Page 12--->Sanitized LED Blinks or Incomplete Sanitization Message at End of Cycle (Control Could Not Confirm Sanitization Achieved)
Do all the checks it says to do there.
  • 665.13409N412 Tech-Sheet-W10751166-Rev C.pdf
katzman299
Kansas
went through the checks and found one concern. The heating element connected at bu/wh and bu/rd shows 11 ohms. Sounds low to me.
katzman299
Kansas
Don't want to declare victory yet, but i ran the dishwasher yesterday on Smart wash with Sanitize on and it ended with Sanitize and Complete solid (no flashing). It has done this before. All I did was to open the door access and unplug the heater to do a continuity test (two plugs 4 wires pulled) and reconnected both, then close it all up.
Very interesting, sounds good.:)
