FIXED 665.13473N411 Kenmore Dishwasher wash motor only runs sometimes
Armin
Bethesda, MD
665.13473N411
All,
I have the same exact unit , 4 years old and same exact issue.
When I put my unit into diagnostic, the screen shows F and then E.
When I shut off breaker for couple hours, the dw works ok for couple of days and then satrt the issue.
Before I buy the motor and pump , I would like to make sure this is issue is related to motor and pump assembly and not the elect board.
Thanks for your help.
Corrected model number
Hi, I moved your post to your own thread here.
Yes, It's most likely a bad wash motor, this has become a common problem as of late, many members here have reported the same. In fact I had 2 this past Sept. 2018 in Parker, Arizona that did the exact same thing, and the new wash motor fixed them both.:)
Look at post #7 here:
I'd first check to see if your getting 120 volts to the wash motor when it should be in the wash cycle.
Take the wire connector off the wash motor and use your multimeter to see if yours is getting 120 volts when it should be washing, if so and it's not running order the wash motor below.
Here is the wash motor assembly:
W11032770 Motor-Pump
Here's the video to replace it:
Armin
Bethesda, MD
Thank you. I will .
Also, I know I saw your post about getting the while assembly with diverter and sumo for almost the same cost as the motor alone. Can you please let me know the exact model number.?
PS. My model number is 665.13473N411.
Your model 665.13473N411 uses that exact same wash motor I posted above in post #2.
Also on your model they DON'T make a complete wash motor/sump assembly you could order.
Ok, sounds good.
Armin
Bethesda, MD
Replaced motor and fixed the issue. Again, thanks for your help. I made a small donation and I hope all visitors who get results donate a small amount for your time and help.
Excellent Armin, glad to hear the new wash motor fixed it. (y)
Thanks for the update and donation!
