665.13543N412 Kenmore Dishwasher not draining.
Jjetrepair
3860 S minuteman way
665.13543N412
I have a 3 yr old Kenmore Elite dishwasher that a glass was broken in and some shards were sucked into the drain pump. I checked the garbage disposal and drain line for obstructions and all is clear. I Ran a rinse cycle and then completed a manual drain. Lights and time would come on but the unit would still not drain. Just removed the drain pump and removed another shard of glass. Impellers still spin but I am wondering if the pump is burnt up. Slow to realize that machine operated a number of weeks with a grinding noise.
Drain Pump WPW10348269
If no more glass shards are in it, then check your voltage with a multimeter at the drain pump electrical terminal wires, it should be 120 volts at the drain pump when its in the drain cycle. If you get 120 volts and the drain pump isn't running, then its bad.
