FIXED 665.13893K800 Kenmore Dishwasher No Power
Loose main power wire, loose/broken wire where the door bends to open and close, bad door switch, bad control are possible trouble makers.
03akkord5spd
GA
Jeff,
So my original problem was loose main power wires, which I fixed shortly after your last post. Now, I have the exact same symptoms again. I double checked the power wires and even re-did the connections with better wire nuts. I also did some more continuity testing.
The relays circled in blue were tested and were good to go. The 4 prong door switch relay I tested while closed and it was good. The 3 prong relay circled in red had no continuity with different prong combinations tested. Is this my problem? I also removed that relay and took a close up picture of it. Thanks again for all the help!
03akkord5spd
GA
False alarm! Turns out a GFCI outlet was tripped and it disabled the power to the dishwasher. Thanks again.
