665.14753N511 Kenmore Elite Ultraclean, sometimes stops mid cycle
Jared McEntire
UT
665.14753N511
This dishwasher is babied, it is 2 years just out of warranty. We are retired, with no kids left at home. Just my wife and I, so since it was new, it only gets used, once or twice a week. We have always rinsed our dishes until basically they are clean. It started doing this about a month ago. There are no lights anywhere, it just stops mid cycle and is getting worse. I thought if I got a fairly nice diswasher, it would last a long time. Now I am wondering if I made the right decision. Has anyone else had this issue before? :wall:
Hi Jared,
What do you mean by "there are no lights anywhere"? Are you referring to when it shuts off mid cycle? All the lights turn off?
When it stops mid cycle is the tub still full of water on the bottom? If so, can you press Cancel/Drain and it will drain then shut off?
If you then start a new cycle it will fill then do nothing? Or do you hear water splashing inside the tub?
Jared McEntire
UT
Thank you for your reply.
Yes, all lights are on the top of the door and all go off mid cycle.
So far there isn't any water in the bottom, so when we push Cancel/Drain, it does nothing.
The odd thing about it is, if we start a new cycle the 2nd time, it runs normal and it goes through the entire cycle and finishes everything.
But 3 to 4 days later when we start it, it again stops mid cycle and since all lights are off, we usually don't know where it is in a cycle.
Jared
Ok Jared,
Since its intermittent like that its going to be very difficult to pinpoint the problem, if it were to NOT start and run normal the 2nd time then it would be much easier to find the problem.
Right now we'd be only guessing the problem, which could be either the control panel or control board.
Jared McEntire
UT
Thank you for your reply, we will just continue to monitor it and see if it changes any more and we will let you know.
Jared
Ok Jared, sounds good.:)
