FIXED 665.15112K213 Not Heating/Drying
vartz04
IL
665.15112K213
This diswhasher worked great up until about 2 weeks ago. Now it doesn't dry and doesn't clean very well at all.
I replaced the high limit thermostat (Cause it was $8 and if i was taking the dishwasher out to test it I figured i might as well just replace it)
I then put the dishwasher back in and ran it, no change
Then i pulled the dishwasher back out and tested the element, that read open so i ordered a new one. Replaced it yesterday and ran the dishwasher again, No Change.
anything else I am missing?
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that now, and report back.:)
vartz04
IL
That appeared to work. Element definitely is hot now. I guess we will see when I load it up with dishes tomorrow
Excellent, yes that always seems to work after replacing the heating element, many members have said the same thing, after I mentioned to them to that SERVICE DIAGNOSTICS CYCLE run through.:)
