FIXED 665.16463300 Kenmore Dishwasher - Replace heating element ?
horsis
new york
Think I am on the right track but i am out of my realm so I ask
symptom
dishwasher smells like something electrical burning when dry cycle
assumption
1 heating element dirty
it is
2 may need replacement
? does element need te be accessed from bottom to be removed ?
does Dishwaser need to be pulled out from under ctr. ?
any help would be appreciated
THANK YOU
horsis
new york
heater replacement part ?
model is 665.16463300
element part #8268559
sears says no longer available
and does not show alternative
any help apreciated
thank you
Ok, on this model you will need a new upgraded heating element/control board kit assembly. They both come together in 1 kit.
The manufacturer has replaced part number 8268559 with this item, part number 8194200.
Here's the one for your model you can order:
8194200 Heating Element Kit
Watch this video:
[video=youtube;Uhib5PxEvaI]
That's good to hear, on some of these Kenmore 665 models all you need is the heating element alone. What is your exact model number?
Yup thanks, your model is one of them where you can order the heating element alone without the control board.
tdalton
NY
I have a 665.17463300. Can I just replace the element with the W10518394 or do I need a control board too? Thanks.
Is your tub plastic or stainless steel?
Yes, If inner tub is plastic order part number W10518394
Yes, that heating element should work on your model.
tdalton
NY
To make it as easy as possible for anyone else: WPW10082892 works for stainless steel tub Kenmore dishwashers such as mine which is model # 665.17463300 and WITHOUT needing a new control board. Now if I could just find a cheap replacment button panel as mine has multi peel spots lol. Here's a pic of the new element installed, it works like a champ! Thank you Jake!
Excellent tdalton, glad to hear that new heating element fit perfect and fixed it. (y)
