665.61622100 Kenmore Microwave loud humming noise, burning smell
Karla Barnes
451 Birkhead
Making a louder humming noise than usual. When I try to use a burning smell come from vent inside the microwave on the right
Sounds like one of the high voltage components. It's probably the diode and capacitor or mag tube. Here's how you test them:
Rick I have a quick question, should the capacitor be discharged first before doing the 9 volt battery test?
No, It's already discharged by the time it's out.
Thanks Rick!
