Thread: LRG3085ST won't heat
    Birmingham
    Default LRG3085ST won't heat
    Model Number: LRG3085ST
    I asked this in another thread with a similar problem, but thought it might be better to post it's own thread. I have a gas range, it will always preheat, but most of the time it will lose temperature, never gets too hot. The display will continue to show the desired temp, say 400, but if you turn it off and back on it will show 200, or whatever the actual temp is. At that point it will not heat back up. It seems to only preheat again after reaching room temp. I have replaced the thermostat and the oven worked as it should a couple of times (coincidence I'm sure), but it's back to the exact same problem.
    LRG3085ST
    Missing a couple of digits.
    I found LRG3085ST/00
    ?Thermostat?
    The oven temp sensor?
    The clock/control board?
    A weak oven hot surface igniter might also be your trouble maker...
    LINK> http://www.applianceaid.com/gas-rang...-help.php#glow
    If needed:
ID:	38597 Oven igniter with wire connector
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Birmingham
    Thermistor not thermostat. I will try the igniter next. Thank you for the help.
    Keep us posted.
  1. Replies: 5
    Last Post: January 28th, 2018, 04:47 PM
  2. Replies: 1
    Last Post: November 11th, 2015, 09:38 PM
  3. Replies: 3
    Last Post: May 7th, 2014, 08:50 AM
  4. Replies: 6
    Last Post: November 6th, 2013, 05:08 AM
  5. Replies: 1
    Last Post: April 21st, 2013, 07:08 PM
