Thread: LDG3031ST Taking too long to heat + Error f19
    Jul 2018
    Connecticut
    Default LDG3031ST Taking too long to heat + Error f19
    Model Number: LDG3031ST
    Double oven, propane. My lower oven has started to take a long time heating up and also has thrown the code F19 four times in the last week. I was thinking about replacing the igniter. Is there any way to test or know for sure? Thanks
    How long is the oven bake ignitor glow bar taking to light the gas when you first turn on the oven?
    The problem is the oven igniter itself is likely weak. It should take about 45 seconds and no longer than 60 seconds to light the gas.
    What happens is when you turn on either the bake or broil cycle the igniter should draw 3.2-3.6 amps to properly open the oven safety valve for bake or broil.
    If you'd like to check it, use an Clamp style Amp Probe around one of the igniter wires. You're looking for 3.2 to 3.6 amps.
    OR
    Here's a diagram Rick made that shows you how to test for 3.2-3.6 amps for the bake cycle. You can use a multimeter to check for 3.2-3.6 amps when its on the bake cycle and see what reading you get.
    (click to enlarge)
Name:	Oven Igniter Test DMM.jpg
    Here's the oven igniter for your model:
    MEE61841401 Ignitor
  1. FIXED: MER8775AS Maytag Electric Range: Pre-heat oven taking too long
    By Mary Jane Dubner in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 13th, 2017, 08:40 AM
  2. FIXED: MGR6772BDS Maytag/Gemini gas range - lower oven taking very long time to heat
    By dieselgg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 4th, 2016, 07:31 PM
  3. FIXED: Maytag Oven taking a long time to heat up
    By sakebomb in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 12th, 2013, 10:28 PM
  4. FIXED: Cooktop taking a long time to heat
    By 95husker in forum Whirlpool/Roper/Estate
    Last Post: April 20th, 2013, 05:05 AM
  5. Oven taking too long to heat up
    By fadgmo in forum Sears Kenmore
    Last Post: June 8th, 2007, 01:48 AM
