Thread: DLE2101W LG Dryer won't start cycle anymore
    Jun 2013
    In the Hills, PA
    Default DLE2101W LG Dryer won't start cycle anymore
    Model Number: DLE2101W
    Hello. Friend has an LG dryer that has been experiencing issues and now won't even start a cycle. It started with a "check filter" error, but at that point it would still run a cycle. Then, it would run, but only with low or no heat (like in a "cool down" mode).
    At this point, it won't even start. Still saying "check filter". We've pulled off the lint hose, cleaned everything that is easily accessible (everything short of tearing the unit apart). I'm pretty comfortable tearing into washers/dryers, but this the first one I've had to deal with that has all the computerized crap.
    Any advice is appreciated. We can totally tear into the dryer and clean the inside, too, if that might help. Figured I'd ask before tearing it apart.
    Thank you!
    I couldn't find any service information on that model but going by your description it sounds like a door switch problem or control board problem.
    When you try to start the dryer does it make any sounds at all? Have you tried all cycles? Including AIR DRY?
    Here's the door switch for your model:
    Door Switch 6601EL3001A
    This video shows you how to access it: LG Electric Dryer Door Switch Video
    This video shows how to ohm test it: Three Terminal Switch Testing Video
    Unfortunately, the control board is no longer available for your model: EBR33640905 Pcb Assembly,main
    Jun 2013
    In the Hills, PA
    Thanks for the reply, Jake. For some reason I didn't get an email notification of your reply (I have it turned on - weird). We will check out the door switch. If it's not that, then it might be time for a new one since the control board isn't available?!?
    Thanks again!
    Yes, Correct.
  1. Replies: 5
    Last Post: March 18th, 2018, 09:55 PM
  2. DLE2101W Dryer comes on but wont turn
    By red22 in forum Dryers
    Last Post: March 5th, 2018, 11:55 AM
  3. No lights on anymore...will not cycle
    By mlloyd996 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 18th, 2013, 04:21 PM
  4. [FIXED] GE Washer Won't Start Anymore
    By surfmaster in forum GE/Hotpoint
    Last Post: February 22nd, 2011, 07:06 PM
  5. Dse515dayw Dryer wont start anymore HELP
    By bigpapaya954 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 3rd, 2011, 10:01 PM
