Thread: FE710DRS Samsung Electric Range bake element wire burnt
    Jul 2018
    Bandera, TX
    Default FE710DRS Samsung Electric Range bake element wire burnt
    Model Number: FE710DRS
    last August I had a lightening strike and my red wire to the lower heating element was burnt. A repairman replaced the connector and the stove worked until about 3 weeks ago. I just pulled the back panel from the stove, and the red wire is burnt again. What can be causing this problem and how can I check what is causing the problem? What can I do to correct this problem
    A bad connection would cause this. The bad connection causes the voltage to drop so the amperage increases to compensate and the poor connection gets hotter and hotter until it burns off.
    I'd suggest getting these parts below.
    High temperature female wire connectors for 10-12 gauge wire sizes
    Generic replacement 12 gauge high temperature wire
    Large red standard wire connectors
    Then you'd need a wire stipper:
    Wire Splicing Tool 959
  1. Replies: 3
    Last Post: October 7th, 2017, 08:03 PM
  2. Replies: 29
    Last Post: March 18th, 2016, 10:46 AM
  3. Replies: 18
    Last Post: December 30th, 2012, 11:10 AM
  4. KESC307HWH1 hidden bake element electric range
    By Eugenestag in forum KitchenAid
    Last Post: December 11th, 2012, 03:50 PM
  5. Kitchen-Aid bake element burnt
    By fmoreno in forum KitchenAid
    Last Post: April 12th, 2011, 10:28 PM
