Thread: HGS3052UC/01 Bosch Gas Oven Temp Off 50 to 75 Degrees
    Aug 2018
    Petaluma, Ca.
    Default HGS3052UC/01 Bosch Gas Oven Temp Off 50 to 75 Degrees
    Model Number: HGS3052UC/01
    Brand: Bosch
    Bosch gas oven model HGS3052UC/01 runs 50 to 75 degrees below setpoint. I need some help on diagnosing the problem. Is there a calibration to adjust or ohm readings to check on the sensor? Any help is appreciated.
    Mike
    Most sensors today are 1000-1100 ohms at room temp ( 70F ).
ID:	39089 Oven sensor
    Bosch doesn't say theirs is any different.
    http://www.applianceaid.com/
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Aug 2018
    Petaluma, Ca.
    Hi Jeff,
    I did not find any info on Bosch sensor readings, so, thanks for the info, I will check the sensor. Looks like the sensor may be connected to the board where the digital read out is, is that right?
    Mike
    Should be yes. Sensor changes resistance to tell the control what is happening.
    Aug 2018
    Petaluma, Ca.
    Hi Jeff,
    I checked the resistance of the sensor and it reads 1.068K Ohms at 71 Degrees, looks like the sensor is ok. What is my next step?
    Mike
    If the sensor is good, that leaves the controlling device(s) as the trouble makers.
    Relay board would not be my prime suspect. The clock/control would be the prime suspect.
ID:	39197 Oven Control Board
  1. Replies: 9
    Last Post: February 3rd, 2017, 12:07 PM
  2. HGS3052UC/01 Bosch Oven - PowerBurner is Low Power
    By mpbeecher in forum Ranges/Ovens
    Last Post: November 8th, 2016, 07:11 PM
  3. Freezer Temp Intermittently Goes Up To 40 Degrees
    By joedol in forum GE/Hotpoint
    Last Post: June 24th, 2016, 07:09 PM
  4. Replies: 9
    Last Post: May 16th, 2016, 09:39 PM
  5. Oven temp 25 degrees below setting
    By gregtachyon in forum GE/Hotpoint
    Last Post: June 6th, 2007, 01:47 AM
