Thread: Gibson RT19F3WX3B - not cooling the fridge nor freezer
    Aug 2018
    Pennsylvania
    Default Gibson RT19F3WX3B - not cooling the fridge nor freezer
    Model Number: RT19F3WX3B
    Brand: Gibson
    - My parents just replaced this fridge which was manufactured in 10/92, and they gave it to me. They did not have any issues with it that I know of. They re-did the kitchen and my mom wanted a new fridge. It sat unplugged for 2 months at their house, and I just put it in my garage to keep drinks and to have extra fridge space. I have had it for about 3 weeks and it worked fine. We went on vacation for a week and when we got back, the freezer was around 45 and the fridge was in the 60's. Lights were on, and I believe that the compressor was running at the time.
    - The condenser is on the back side. It is clean. The evaporator is in the rear of the freezer. When I took the rear cover off, there was about a 1x2" chunk of ice on the right side of the evaporator around the defrost thermostat. The evaporator did not have any frost on it.
    - The fan runs as soon as I turn the temp control on. The fan is circulating air that is not cold. It does not sound loud or unusual. When I touch the one line from the compressor to the evap it is pretty cool, but not as cold as I would think that it should be. When the compressor runs it does get pretty warm, but I don't think that it sounds loud or anything.
    - We had Bible School every evening last week, so I did not mess with it for over a week now. If I turn it on, it will run, but the temp does not change.
    - I saw somewhere on the internet, that if you ohm the 3 legs of the start relay, adding two of the 3 values together should equal the value of the third. I think when I did that 2 were about 3.2 ohms and the third was 6.5. The relay was $8 so I did replace that, with no improvement.
    Thanks, Dan
    Here's a diagram for checking the relay/overload and the compressor windings:
Name:	R -Compressor Windings Test A.jpg
ID:	39209Click image for larger version.
    If the compressor is running you have a sealed system problem, either a refrigeration leak or system restriction. Sealed system repairs are expensive and will often exceed the machines value.
  1. Replies: 9
    Last Post: June 14th, 2017, 05:45 PM
  2. Gibson GRT16CRH Refrigerator Not Cooling
    By jerkyboy in forum Refrigerators & Freezers
    Last Post: September 2nd, 2013, 08:53 PM
  3. Gibson Fridge/Freezer not getting cold and other problems.
    By JaPithus in forum Frigidaire/Electrolux
    Last Post: December 28th, 2011, 06:13 PM
  4. Gibson freezer cold but not freezing
    By Laura877 in forum Refrigerators & Freezers
    Last Post: September 12th, 2011, 05:11 PM
  5. Old Gibson Chest Freezer Not Freezing
    By Bill Westfall in forum Refrigerators & Freezers
    Last Post: July 20th, 2006, 01:59 PM
