Thread: CAW9244DW1 Crosley Washer Drain Pump Always Runs
    Sep 2018
    SW Louisiana
    Default CAW9244DW1 Crosley Washer Drain Pump Always Runs
    Model Number: CAW9244DW1
    Brand: Crosley
    Hello All,
    New to the forum and trying to help a friend out that has hit hard times and is not able to purchase a new washer. The Crosley washer is approximately two years old, no matter what cycle is selected the drain pump constantly runs (for as long as you'd allow it to) when the start button is pressed until the cycle is cancelled. Went into diagnostic mode and the unit will fill, spin, agitate and of course drain manually. Unplugged the unit for one hour, set the dial to "Regular", plugged it back in and still the same issue. Next selected "Drain and Spin" cycle and when start is pressed the original issue remains. Verified great water pressure to the unit supply ports and ensured the drain hose is high enough to prevent siphoning. Any and all assistance is appreciated, Thanks!
    **Edit - Also, the machine will not complete or initiate calibration in diagnostic mode. Also, when a normal cycle is selected and the start button is pressed the "Fill" light only quickly flashes before extinguishing.
    Last edited by rickgburton; September 5th, 2018 at 03:49 PM. Reason: added model number
    Without a model number, we're dead in the water. Read it from the tag on the machine. Click here: http://www.repairclinic.com/ follow the link “What is a model number, and where do I find it?”
    Sep 2018
    SW Louisiana
    My apologies, when I wrote the post I didn't have the model number. It is CAW9244DW1
    Sounds like a bad control board: W10671332 Electronic Control Board
  1. CDT765SSF0SS GE dishwasher - drain pump runs dry
    By JJG0623 in forum GE/Hotpoint
    Last Post: April 19th, 2018, 10:49 PM
  2. FIXED: New Pump runs and drains, but drain does not close
    By Puckboy106 in forum GE/Hotpoint
    Last Post: June 20th, 2014, 08:15 PM
    Last Post: April 22nd, 2014, 09:53 PM
  4. FIXED: WFW9400SW01 Whirlpool Front load washer drain pump runs constantly
    By SBdoes in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 21st, 2013, 11:01 AM
  5. GE Dishwasher Drain Pump Runs On
    By ZCspeed in forum GE/Hotpoint
    Last Post: December 12th, 2011, 11:27 PM
