Thread: WM3470HWA LG Washer no longer turns on
    Jan 2008
    Minneapolis
    Default WM3470HWA LG Washer no longer turns on
    Model Number: WM3470HWA
    Long time member ��
    It seems our washer will no longer turn on. A month ago it did the same so I flipped the breaker and it worked. Then a few weeks ago did it again, just never turns on (no power lights, nothing). I went and switched the washer dryer plugs around to different outlets, it worked. Now today the washer will not power up despite flipping the breaker and switching outlets.
    I am suspecting it’s the circuit board.....
    BTW, I don’t think the breaker or switching outlets did anything (lol) but worth a try right?
    Measure the voltage where the power cord connects to the noise filter and then where the noise filter connects to the main board. If the voltage is correct (120 VAC), disconnect and reconnect each wire connector. Check the pins in the connectors are not backing out of the connectors. Replace the main board:
    Main Control Board EBR78263901
    Jan 2008
    Minneapolis
    Thank you... part ordered..
    Did you do the voltage checks?
  1. FIXED: 110.26832692 Washer no longer turns on but water still flows
    By Kelemvor in forum Sears Kenmore
    Last Post: October 7th, 2017, 04:29 PM
  2. WM3470HWA LG FL rear tub seal leaks
    By discgolfdc in forum Washers
    Last Post: October 6th, 2017, 07:11 PM
  3. DWXR463EGWW Dryer no longer turns on
    By soup006 in forum GE/Hotpoint
    Last Post: January 10th, 2017, 10:29 PM
  4. Replies: 3
    Last Post: August 24th, 2016, 11:22 AM
  5. Replies: 3
    Last Post: July 28th, 2015, 01:03 PM
