Results 1 to 3 of 3
Thread: DV365GTBGWRA Samsung dryer leaking water during steam cycles.
    May 2008
    Alberta
    Default DV365GTBGWRA Samsung dryer leaking water during steam cycles.
    Model Number: DV365GTBGWRA
    I notice that when I use the "refresh" cycle or any cycle that uses the connected water for steam, there is a puddle of water on the floor by the front right corner of the dryer. At first I thought it was perhaps the hose loose at the back, but if that was the case it would leak all the time, not just when using a steam cycle.
    I recently had the dryer apart to replace the drum rollers and idler - could I have bumped something that is now causing water to leak?
    thanks in advance
    Hi Glen,
    Here's the parts diagram for your model: Samsung Dryer DV365GTBGWR/A3-0001 Repair Parts
    Was it leaking this water before you took it apart to replace the drum rollers and Idler Pulley?
    May 2008
    Alberta
    Thanks Jake
    That's a good question - we hardly use the steam option but from what I can remember I don't recall it ever leaking before, so it could be just a coincidence or maybe I did something while I was replacing the drum rollers etc.
    When I get a chance I will take it apart and see if I can see if the leak is at an obvious place.
  1. Samsung RSH77NRS leaking water
    By seftonbarn in forum Samsung
    Last Post: March 19th, 2017, 03:01 PM
  2. Replies: 9
    Last Post: February 21st, 2017, 09:01 PM
  3. FIXED: LG Side load steam washer. Leaking
    By soundfixer in forum Washers
    Last Post: May 12th, 2016, 09:35 PM
  4. Samsung VRT Steam Washer will not spin
    By chrisswany in forum Washers
    Last Post: January 31st, 2016, 01:01 PM
  5. Replies: 3
    Last Post: July 3rd, 2015, 03:44 PM
