Thread: Samsung DW80F600UTS No power
    Jun 2017
    MI
    Default Samsung DW80F600UTS No power
    Model Number: DW80F600UTS
    Hello everyone.
    What an absolute abomination of an appliance.
    I'll get right to it.
    No power to this thing all of a sudden.
    Check power at the unit, good.
    Killed the power over night.
    Power back on in morning.
    Nothing.
    I searched on here and came up with the display control board first. So,
    Tried changing the display control board. DD92-00037B nothing.
    What's next?
    The Power Board #DD92-00033C?
    Ryan.
    How was that checked?
    We see many loose wire nuts where the power comes into the d/w.
    What's next?
    If the key panel did not help, might as well try the main board.
    http://www.applianceaid.com/
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Jun 2017
    MI
    First, put my meter probes into the wire nuts, and there was power.
    Then removed the wire nuts and re-attached them. Thinking the same thing.
    Main board will hopefully be here by Friday.
    If you get a chance, let us know how the repair went.
    Jun 2017
    MI
    Quote Originally Posted by jeff1 View Post
    Got the power board, the DD92-0033C actually it's a rev B but I highly doubt that matters.
    Tried that. Didn't work either.
    What's next, besides the dumpster.
    It does matter.
    Grab the full model# and any version numbers after the model#.....post them here.
    Jun 2017
    MI
    It does matter.
    Jeff, I'm certainly not questioning your knowledge, but if the B to C makes a difference on the same part number than Samsung is even worse than I thought. That would be a horrible method to numbering parts. In my world (automotive) that's just a rev up.
    Anyway,
    Model- DV80F600UTS
    MC -DW80F600UTS/AA
    S/N B00AG9MD706100K
    Those are zeros in the S/N not "ohs"
    MC -DW80F600UTS/AA
    Anything after the AA? Or post a picture of the model/serial tag.
    I found DW80F600UTS/AA-00 DW80F600UTS/AA-0000 DW80F600UTS/AA-0001 DW80F600UTS/AA-01
    DW80F600UTS/AA-00
    Touchpad
    Display board
    Power control board
    Noise Filter
    DW80F600UTS/AA-0000 got an error, couldn't look up anything.
    DW80F600UTS/AA-0001 got an error, couldn't look up anything.
    DW80F600UTS/AA-01
    Touchpad
    Display board
    Main Control Board
    Noise Filter
    Of the 2 I could look up the key panals appear the same but the pcboards are different.
    Jun 2017
    MI
    Nope that's all the data.
    I tried the touch-pad.
    How can the display board cause a no power issue? Isn't that just LED's.
    The noise filter on the schematic just looks like it's in parallel to the circuit off the heater, drain pump and washer motor. Neither of which SHOULD cause a no power situation.
    Interestingly enough, the part number on the power control board I have is DE41-00391A. Neither of which show up on your query? Why is that? Actually the one I replaced it with has the same part number on the board. I don't see the DD92-00037A or B anywhere?
    I do have power into the board at the "live" terminal. T201
    Terminal CN101 the Red plug on the far left also has power into the board with the jumper wire.
    I don't see anything after the model#.....as the version number was just kinda floating in the air on the tag so it looks like DW80F600UTS/AA-00 should be the correct parts lookup.
ID:	40092 DD92-00033C
    DE41-00391A comes up as nothing for me.
    I picked them also at the same time as other Samsung d/w's have had to have these replaced for dead issues. I don't have a wire diagram in front of me but a line filter is more often than not in the main power supply.
  1. Replies: 22
    Last Post: September 11th, 2017, 06:46 PM
  2. Samsung DW80F600UTS/AA continuously drains.
    By Tomdolan79 in forum Samsung
    Last Post: May 14th, 2017, 09:40 PM
  3. Samsung Dishwasher DW80F600UTS/AA Drain-In Hose
    By mhurley131 in forum Dishwashers
    Last Post: March 16th, 2017, 10:29 AM
  4. Samsung dishwasher DW80F600UTS stops mid cycle
    By racheltwu in forum Dishwashers
    Last Post: August 13th, 2016, 09:42 PM
  5. Replies: 6
    Last Post: January 21st, 2015, 08:49 AM
