Thread: Maytag bravos washer error code ld
    Pennsylvania
    Default Maytag bravos washer error code ld
    Model Number: NEED
    Brand: Maytag
    Hi everyone my washer the other day was finishing up rinse cycle and it got an ld error code. The old I did before our daughter must have thrown a diaper in and it exploded I sucked the inside out of the tub with a shop vac but thinking maybe something got inside the pump? I unplugged it for 5 min and plugged it back in and I hear Im assuming the pump humming but nothing else happens then after a few minutes it shuts off then it comes up with the code. After I power it off it still bums for a little bit maybe a minute or so. Does this seem like a clogged pump or something else?
    Howdy Shoe,
    We need the model number of your washer first, the model number tag should be inside the door.
    Yes, it sounds like you have a foreign object stuck/jammed in your drain pump, or your drain pump bearing has seized up.
    Pennsylvania
    Hi jake
    I actually ripped it apart today and found some socks inside the drain pump. It is working like new now. I also cleaned it really good. Thanks for the response
    Sounds good Shoe, glad that's all it was.
  1. Maytag Bravos XL Ld and F32 error code
    By buefordTJ in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 8th, 2016, 02:57 PM
  2. Maytag Bravos washer - "du" error code
    By Tweedy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 23rd, 2016, 01:28 PM
  3. MTW6700TQ1 Maytag Bravos Error Code Sd
    By Jsmalls in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 11th, 2014, 09:37 AM
  4. Maytag Bravos XL MVWB850YW0 Error Code F:54
    By kyosuke75 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 10th, 2012, 05:08 PM
  5. Maytag Bravos XLHE Top - 'F1' error code now 'du'
    By OffRoadn in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 1st, 2012, 02:20 AM
