Thread: Electrolux EW30EF65GSB F10 hours after use
    Nov 2018
    NJ
    Default Electrolux EW30EF65GSB F10 hours after use
    Model Number: EW30EF65GSB
    Brand: Electrolux
    Hello.
    I have an Electrolux EW30EF65GSB range. Lately its been displaying F10 error and beeping. What is weird is that it displays this error and beeps hours after use. We used an oven yesterday and it started beeping 24 hours later. Oven is not hot. I checked inside and there is no heat. its cool. Unplugging it and plugging it back into power fixes the issue.
    Any ideas on how to fix this?
    thank you
    Alex
    Canada
    Question Oven sensor malfunction?
    That error is suppose to indicate a "Runaway temperature. Oven heats when no cook cycle is programmed".
    If the oven is definitely not heating at the time, the oven sensor may be giving erroneous readings to the control at that time.
    LINK > Electrolux EW30EF65GSB Oven Sensor
    Check the sensor's resistance when the error is occurring. If the reading is within specs, check its wiring. Maybe a mouse got in and is chewing on the sensor's wiring?
    LINK > How do I check an oven temperature sensor?
    If both are Ok, the control may be malfunctioning and need to be replaced.
    LINK > Electrolux EW30EF65GSB Electronic Control
    Dan O.
    Nov 2018
    NJ
    Thank you Dan. Question - how would i test it while error is occurring? If i power off the oven, error goes away
    Canada
    Lightbulb
    Quote Originally Posted by apal
    I meant not wait several hours or until the next day, etc. Test it as soon as the error occurs.
    If you can isolate the sensor's wiring where it connects to the control, the resistance might also be able to be tested right at the control without disconnecting it. That can be tricky to do however and not always possible. When Possible that can however enable testing the sensor and wiring at the same time.
    Dan O.
  1. Replies: 5
    Last Post: December 14th, 2017, 12:24 PM
  2. FIXED: EW30EF65GSB Electrolux wave touch F10 code
    By powelljr1962 in forum Frigidaire/Tappan/Electrolux
    Last Post: July 16th, 2014, 10:12 PM
  3. Frigidaire GSB5755DS HO for 3 hours
    By tshurd in forum Frigidaire/Electrolux
    Last Post: March 12th, 2008, 06:01 PM
  4. 7 hours after new refrigerator delivery
    By TR7Spyder in forum GE/Hotpoint
    Last Post: February 17th, 2008, 10:39 PM
  5. 5 Cubes every 8 hours on a Kenmore, what gives?
    By polvadis in forum Sears Kenmore
    Last Post: April 30th, 2007, 12:43 PM
