Results 1 to 5 of 5
Thread: LDG4313ST Turn off or remove speaker from LG gas oven
    Nov 2018
    St Clair Shores MI
    Default LDG4313ST Turn off or remove speaker from LG gas oven
    Model Number: LDG4313ST
    Hello. I have an LG gas stove with two oven compartments, 2.5 years old. There seems to be no way to completely turn off the speaker. Every time the oven reaches its set temp it plays a very annoying song that is making my dog stroke out. I found a YouTube video that shows the removal of the speaker from the control board of an electric LG, but nothing on a gas unit. I've removed the control board and can't find anything that looks even remotely like a speaker. Can anyone tell me how to turn it off or how to find it on the board so I can remove it?
    I've been looking for the service manual for that machine but unfortunately I haven't found anything. I'm sure there is a way to switch between a beep tone and a song in service mode. PCB speakers are easy to identify so I look up the ERC for your machine. It's not visible on the front or back of the board which means it located between the LCD and the board. That's a common place for it. It's not easy to get to but you can look on the back of the board and see if the manufacturer labeled it or put the electronic symbol for a speaker. The range control uses the beep tones for error codes so before you disconnect it give me a day to see if I can find the manual. Do you have your tech sheet?
    Mar 2015
    From Planet Mars
    Looks like they talk about that on page 2-3 and 2-4! Here is that service manual.
    Attached Files Attached Files
    Thanks bigbuck!
    I didn't see anything about playing a song but according to the manual you should be able to turn it off.
    Adjusting the Beeper Volume
    1. Touch Settings repeatedly until Beep appears in the display.
    2. Touch 1 to select Hi, Lo or Off.
    3. Touch Start to accept the change.
  1. Replies: 4
    Last Post: September 9th, 2017, 05:39 PM
  2. GE Profile PFE28RSHSS no sound from speaker
    By NinoV in forum GE/Hotpoint
    Last Post: August 9th, 2017, 11:05 AM
  3. Oven control board turns off when I open oven door or turn on oven light
    By HelenSpears in forum Frigidaire/Tappan/Electrolux
    Last Post: November 29th, 2015, 08:01 PM
  4. How to remove oven door
    By sonnyboy in forum KitchenAid
    Last Post: January 30th, 2013, 02:28 AM
  5. Remove probe from oven
    By btrossman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 13th, 2011, 12:30 AM
