Thread: WT1701CW LG Random power up/power down no codes
    Nov 2018
    Cypress, TX
    Default WT1701CW LG Random power up/power down no codes
    Model Number: WT1701CW
    Hello,
    I have a 3 year old LG WT1701CW topload washer and it recently started powering down between cycles.
    I could power it back up and run the rinse/spin cycle but if I tried to run the wash cycle it may or may not make through the process. Sometimes it works perfectly.
    Sometimes the touch panel won’t stay on long enough to select a cycle.
    It just completed a wash cycle without issue and turn itself off. Then 2 minutes later the power on music came on by itself.
    I thought something might be getting wet. I pulled the control board an visually inspected it.
    The boards are potted well and no visible moisture or damage was noticeable. Disconnected all the plugs and reconnected looking for loose or poor connections.
    Any suggestions?
    Usually when this happens it indicates a short in your touchpad assembly.
    Here's the touchpad assembly for your model: EBR75934205 Pcb Assembly,display
    Its currently out-of-stock.
  1. FIXED: Maytag MEDC400VW0 - Power Issues, moving the power cord helps.
    By gr00316 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 4th, 2017, 11:34 AM
  2. FIXED: Frigidaire Double Oven random heating malfunction without error codes
    By michigan-dreaming in forum Frigidaire/Tappan/Electrolux
    Last Post: December 17th, 2014, 11:26 PM
  3. Replies: 21
    Last Post: July 23rd, 2014, 09:36 PM
  4. Replies: 5
    Last Post: October 7th, 2012, 01:06 PM
  5. Replies: 3
    Last Post: October 4th, 2011, 07:27 AM
