Thread: FAQE7111LW0 Dryer will not shut off after cycle set time
    Nov 2018
    north carolina
    Question FAQE7111LW0 Dryer will not shut off after cycle set time
    Model Number: FAQE7111LW0
    Brand: Frigidaire
    HELLO...our dryer has started to quit shutting off after the cycle time has been set..example(60 min) will run till you stop it by opening door or pushing cancel button
    tried differrent heat settings still same effect will not shut off cloths will be dry but dryer continues to run.....dryer was purchased in december 2012...so 6 years old..have any of you had this issue and is there something i can do to correct this...by the way exshaust pipe is not obstructed flows free ..any help is appreciated thanks ..by the way frigidaire model FAQE7111LW0
    Relay on the board is sticking/stuck = new board time.
ID:	40748 LINK> Dryer electronic control board
    http://www.applianceaid.com/
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Dec 2018
    LBNY
    Hi Jeff! I see that you're the go-to-guy here (at least for Frigidaire).
    I've got the same dryer and a similar problem -- sometimes it's the same as the OP (not stopping after cycle). Other times I'll just throw something in and take it out before the cycle is done but the dryer keeps going (no heat) even after I pause or cancel from the panel.
    I'm assuming I need a new board since that seems to be the solution for these kinds of problems, right?
    Definetly shouldn't do that!
    That is very possible.
  1. FSE446RHS2 Dryer will not shut off after drying cycle
    By busyguy in forum Frigidaire/Electrolux
    Last Post: July 16th, 2017, 08:08 AM
  2. Maytag Centennial Dryer stops mid time cycle
    By Rickm8811 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 5th, 2016, 02:51 PM
  3. Frigidaire Gas Dryer likes to shut off and turn on during a cycle
    By mountainbiker33 in forum Frigidaire/Electrolux
    Last Post: January 26th, 2015, 08:08 AM
  4. FIXED: The Buzzer At The End Of The Dryer Cycle Comes On But Won't Shut Off
    By coollx in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 29th, 2010, 02:57 AM
  5. Dryer will not shut off after dry cycle
    By Dennis7894 in forum Sears Kenmore
    Last Post: May 24th, 2010, 07:29 PM
